Showing results forĀ
Search instead forĀ
Did you mean:Ā
Integer Factors
Of course you should always have one of these on the thumb drive on your keychain. Smiley Wink
Message 11 of 18
(4,780 Views)
fxgbhsfh wrote:
Create a vi that determines all the factors of an integer that is input by the user. The results should  be displayed in an array. display only the factors on the front panel (no zeros) .
Are you looking for all possible integer factors or for all prime factors (a more typical problem).
Message 12 of 18
(4,771 Views)
Not sure what this is
Message 13 of 18
(4,729 Views)
That is an empty array constant.  Put an array constant down on your block diagram.  Do the same for a numeric constant.  Now drag the numeric constant into the array constant.  You will need to set the numeric representation to I32 to make all of the data types correct.
Message 14 of 18
(4,724 Views)
Of you could just wire up everything else first, then right-click the left shift register and select "create constant". One step! šŸ˜„
Message 15 of 18
(4,696 Views)
What is the 1, for the first case, and the false for the second case.
Message 16 of 18
(4,635 Views)
Hi HylerTeck,
Here are the screenshots of the two cases.
The example is a VI Snippet. VI Snippets, as a png file, can be saved to your computer and then dragged to an empty VI. A VI Snippet is a special png file that contains the LabVIEW code.
True Case:
"1" Case
Jordan G.
LabVIEW Product Marketing Engineer
Message 17 of 18
(4,598 Views)
1, Default  So the remainder of Number and "i"+2 is something other than zero. (So multiplying "I+2 by any number will not = number- it is not an integer factor - toss it out!)
2.   i+2 = Q  we don't need to duplicate the square factor.  e.g if Number is 25 and i is 3 Quotient and i+2 are both 5
(Wow that was a long time between bumps)
Message 18 of 18
(4,588 Views)
