Integral x(t) PtByPt
@JÞB wrote:
@Thoric wrote:
@JeffMotes wrote:
Yes
Bimey. I didn't know that was possible. Deploying to FPGA from Windows, via a LabVIEW dll. Sorry, but that's not something I feel I can help with anymore. Maybe a blue member can jump in here and assist?
That certainly sounds possible!  Calling a dll created from a LabVIEW build to export a LabVIEW wrapper to lvanlys.dll from LabWindows SHOULD work (albiet, its a rather "round about" way to get to a solution.... seriously! call the lvanlys.dll function directly)
What may not be possible is the floating point math operations being targeted to a FPGA!  What lead you down this "long strange trip?"
Spoiler
I can use that quote from Jerry Garcia, I'm from Minnesota too!
Jeff, the calling of Integral from a dll is certainly possible, it's the FPGA deployment that's got me wondering. How would a LabVIEW dll, in Windows, deploy FPGA code?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 11 of 12
(541 Views)
I'm not exactly sure what you mean by deploy but the FPGA portion is not my problem.  I have been doing what I need there for a while now.  My only problem is using the PtbyPt Integral function in a LabView VI and calling it from LabWindows.   With the Integral function in the VI, the call from LabWindows hangs execution.  I can remove the function and rebuild and LabWindows does not hang.
I have a LabView Project that contains FPGA VIs.  Within that project, I have other LabView VIs for downloading and running the FPGA VI code.  It is the download, run, etc VIs that I complile into a DLL that is executed from LabWindows.  I hope that explains my situation a little better.
Message 12 of 12
(537 Views)
