Integration LVM file
Hi, sorry if my english is not the best
I need to process this signal, but one of the processing steps is to integrated it (as if I had an op amp in integrator mode), if I put the integral block directly it would show me a linear function.
Can you help me to check, why am I wrong?
(2,308 Views)
Hi Emilio,
You are wrong in two ways:
  1. By attaching just images we cannot run/edit/debug your VI. How can we help you when you don't supply your code?
  2. Your signal values only fluctuate between 20 and 21: which kind of signal other than an (nearly linear) steadily increasing line do you expect?
(2,267 Views)
Hi all, actually I upload the signal file into a txt file by using matlab, i dont know if it would help.
Actually this is the flow signal of an spirometer, but the theory sais that if i want to have the volume signal i need to integrated it and then find the min and max values, it would integrate the signal, but it appears to be linear, i dont know if i am doing something wrong.
It needs to appear similiar to the orignal signal,
(2,248 Views)
Hi Emilio,
Your signal has a small range (max-min) of just ~1.0, while it has a huge offset of ~20.5.
What happens when you integrate such a signal? (What did you learn at school about the math integration operation?)
What happens when you subtract the mean of the signal before integration?
(2,243 Views)
