convert vector into a scalar in simulink
hello!
i am facing some challenge on converting a vector matrix into a scalar in the simulink. is there any block in the simulink that can convert a vector into a scalar?
Thanks!
(2,568 Views)
Hi Bitec,
Do you know you wrote this message in a LabVIEW board, which is not related to Simulink at all?
Why don't you write your question in a Simulink-dedicated forum?
(2,537 Views)
As has been said, Simulink is not a NI product, but can be used with LabVIEW and other NI products.
Your question is way too vague to give an answer. A vector is worth at least two scalars (RE&IM or magnitude&direction), so converting a vector into a scalar is a lossy proposition and you need to decide what you want to keep. Please provide significantly more detail!
(2,529 Views)
