Integration of Graphs
Dear guys,
I will like to do a compilation of my results into only 1 graph instead of the current approach i am using by assigning one graph to each function. I was thinking is it possible to use the "property node" to achieve this target? If not, can anyone suggest how the intergration could be done? In addition, i realize my graph constantly "jerK" due to the sudden changes in my x and y coordinates, is this cause by the autoscalling function of the graph?
Best Regards,
Scott
Message 1 of 9
(4,837 Views)
Hi Sena_Scott,
-Why not use multiple plots in graph?
-Check Mixed Signal graph in the link: https://www.ni.com/docs/en-US/bundle/labview/page/types-of-graphs-and-charts.html
-Yes, the "jerK" sudden changes are due to autoscale in X and Y-axes.
uday
Message 2 of 9
(4,821 Views)
Hi udka,
My bad, i think i phrase my question wrongly. My programme is as such,
3 different functions with three similar outputs of x - y coordinates. However i will like the graph (Final outcome) to show only the coordinates of whichever function i have selected. I was thinking to assign the values into a property node and whenever one of the function is selected, the value will be send to the Graph i wanted. No intergration is needed but i want my graph to show the correct data from 1 of the 3 outputs i selected.
Best Regards,
Scott
Message 3 of 9
(4,811 Views)
You could use a case structure as a selector
Btw, what is the reason that you use multiple waits?
And instead of build xy graph function, you can also use the cluster function.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 4 of 9
(4,804 Views)
Yes, you can do that by simply taking the Property Node >> Value of the chart and supply appropriate value using case structure.
uday
Message 5 of 9
(4,800 Views)
Hi udka,
why do you mention chart properties when the OP is using XYGraphs?
Message 6 of 9
(4,790 Views)
Thanks udka and Koen94,
However as my output is a 1D Array of cluster 2 elements, I was unable to connect to the property node. Does property node only accept 1D values?
Best Regards,
Scott
Message 7 of 9
(4,755 Views)
Best Regards,
Scott
Message 8 of 9
(4,755 Views)
Accepted by Sena_Scott
I don't see your problem, you have a 1D array of clusters.
It should work.
it also works with arrays, if that is what you mean. Though you have to connect it to the xy graph once.
Message 9 of 9
(4,742 Views)
