Intensity graph X value display
I have a specific problem. I have to plot some samples( say for example 15) in the Intensity graph, but I want to display the following values in the X axis instead of sample number(it means instead of sample number, I want to display when/Where it occurred). Is it possible in LabView in any way?
X Values
0
0.2
0.4
0.6
0.8
1.0
2.0
3.0
4.0
5.0
5.5
6.0
7.0
8.0
9.0
10.0
Rathan
(3,013 Views)
Since your data is not spaced linearly with array index, this is not easily possible.
There are currently two ideas that could deal with this limitation:
In the meantime, you would need to find a more creative solution. Certainly possible but it won't be easy or pretty. 😉
(3,000 Views)
