here i attached my block diagram ad an exmaple of trending which i did using excel. thank you
01-21-2010 02:01 AM
01-21-2010 02:24 AM
I think you forgot attach the VI.
but to my unserstanding i think you need following thing.
Regards.
Shrek
01-21-2010 04:34 PM
shrekt, i'm sorry i didnt attach eralier, here i attach my block diagram.
the 1 u gave if similar to what i intended to do, but when i try to modify my block diagram, i gave me error as i attach also the picture 'after modified' together. hope u got some tips on it. thankz
01-21-2010 11:39 PM
Actually the output of the you build is 1D array and the table is 2D array so the error is there.
convert that array into 2D, oe else attach the vi.
Shrek
01-22-2010 12:57 AM
01-22-2010 01:21 AM
Hi
right click on build array and un check concatenate inputs option. see if its works then
01-22-2010 10:57 PM
HI,
I have done it for you, check the following ex.
Regards
01-23-2010 12:08 AM
01-23-2010 12:14 AM
Where do you want to save the data, (on the control, text file, or any other ?)
01-23-2010 12:15 AM
