how can i do rms data trending using labview
i wish i can save it in a text file
Message 11 of 28
(1,332 Views)
Use Write to spreadsheet file and add extension txt
Message 12 of 28
(1,321 Views)
thank you..is there anyway to change the time and date on the graph?
Message 13 of 28
(1,314 Views)
To my understanding LV take the system time only.
But if u are facing problem of the year 1900 then you can create waveform and add current time to it
regards
Message 14 of 28
(1,310 Views)
the time and date on the table thus show the system which is the current date and time, only the graph shows 1904 each time. by the way, thank you and your help is much appriciated
Message 15 of 28
(1,299 Views)
Check out the following ex.
Message 16 of 28
(1,297 Views)
this example graph do show the real present time and date. is it posible to have it done on the VI before?
Message 17 of 28
(1,279 Views)
Open the example finder and search for 'Chart'. Open the example called Real Time Chart. Do the same thing as in the example to program the chart to display the actual time. The example uses relative time but you can modify it to show absolute time.
p.s. Your case that reads the file is just silly. Absolutely no reason to read the entire file with every iteration of the loop. You are just wasting resources.
Message Edited by Dennis Knutson on 01-23-2010 07:57 PM
Message 18 of 28
(1,272 Views)
hai dennis, do you have any idea on how can i read it efficiently
Message Edited by hafizzuddin on 01-23-2010 09:39 PM
Message 19 of 28
(1,265 Views)
Put the read outside the loop. Or is you intention to give the user the ability to read a different file? An event structure would be better for that.
Message 20 of 28
(1,260 Views)
