Intensity graph displays a black z-axis color bar
Dear Devs,
using LV2013.02f, when displaying some 2D array of values, I see a black z-axis color bar (see inset or attachment), although the min and max of the array are identified correctly (shown next to the graph). Is that reproducible to anybody? How can show the full corresponding (white-blue-black) color scale for the z-axis?
Cheers,
(3,475 Views)
Hi ghi,
please stick in one thread the next time...
Those are very small values you're working with. What happens when you scale them up by 1E33?
(3,468 Views)
Dear GerdW,
thank you for your suggestion.
So, I multiplied my values by 1e32 and the picture is the same, see attachment, please.
Cheers,
Off-topic: I do not see, how the two issues are connected, except that they are both connected to the intensity graph. Not to the values
a) I can take any input from my measurement set, evaluate it and display and the two issues are reproducible on my system.
b) There are several posts from mature forum contributors NOT to mix issues and problems into a single topic. And that is a good habit in other non-NI forums, too. If your clearly see, that the two issues are connected, I cross link them in a minute easily.
c) Do you really suggest posting messages with subjects like "my graph displays A when option B and the axis does not displays C when D and moreover the border flashes purple when E" and messages with several paragraphs and attachments? (I am not a good writer, I loose focus, my readers might, too, so I keep my messages as short as possible.)
(3,453 Views)
Dear GerdW,
you had a good sense about the connection between the two issues. But how the hell should a user know about it, before the issues are elaborated and solved? I stick with less cluttter within a single message...
Related issue:
Intensity graph and its "interpolate color" option
Cheers,
(3,433 Views)
