Interface Labview with Vitrek V76 Hipot
Hello there, i need solve one problem with the interface Labview with the equipment Hipot v76 Vitrek.
So the issue is, i have download the Vi Controls for the equipment but i need to make switch configuration to make functional the rear panel of the tester but i didn't found the way to made that switch functional with labview, i can made this procedure manual with the tester but i need to make automatical with the intercace,
is there other Vi's to make that possible? or what i need to do to make functional the switch configuration from labview, i have already take some support of vitrek but they told me i need to add functions to issue the switch step commands but i didn't know how to do that.
Hope someone have solution for this problem.
Message 1 of 1
(1,215 Views)
