Interface between LabVIEW and C#
     Again we are trying to send the data in bigger project in C#.There they have provided the function        "m_socListener_server.BeginAccept(new AsyncCallback(OnClientConnect), null);" in which BeginAccept(new AsyncCallback(OnClientConnect), null) is a function of Socket class and m_socListener_server is an object reference of that Socket  class through which we are calling this function.The above written function is not accepting the data from Labview.How we send the data through socket??
Thanks as kudos only:)
Message 21 of 36
(5,155 Views)
And how is it not accepting the data? The BeginAccept is not accepting anything anyhow, it just starts an asynchonrous thread that is waiting for connection requests to arrive.
Is this with the data server in LabVIEW? Then you need to think again! BeginAccept() waits for connection attempts by a client, not for data from a server. Begin Accept is similar to the TCP Listen primitive in LabVIEW, not to TCP Read.
You are always providing information in litle pieces which ends up in a ping pong game about requesting extra informations and getting part of that and requesting more, etc. This is very frustrating.
Rolf Kalbermatter  My Blog
Message 22 of 36
(5,153 Views)
     Now we are able to send data from labview to C# and it is displaying in the bigger project written in C#.But we are unable to update the data, that is after changing any of the inputs,the change not get reflected in C# application.But after stopping and again running that change can be visible.where will be the problem.Below is our C# code.Please give necessary instructions.
 System.Net.Sockets.TcpClient clientSocket = new System.Net.Sockets.TcpClient();
           byte[] inStream = new byte[10025];
           ArrayList list = new ArrayList();
           ArrayList orglist = new ArrayList();
           ArrayList Andata = new ArrayList();
           ArrayList didata = new ArrayList();
           ArrayList FFrame = new ArrayList();
           string st="";
            try
                 clientSocket.Connect("127.0.0.1", 8221);
                 NetworkStream serverStream = clientSocket.GetStream();
                 serverStream.Read(inStream, 0, (int)clientSocket.ReceiveBufferSize);
                 // soc.BeginReceive(theSocPkt.dataBuffer, 0, theSocPkt.dataBuffer.Length, SocketFlags.None, pfnWorkerCallBack_server, theSocPkt);
                  //int x = inStream.Length;
                  System.Text.UTF8Encoding enc = new System.Text.UTF8Encoding();
                  string str = enc.GetString(inStream);
                  char[] strToParse = str.ToCharArray();
                  int n=str.Length;
                  //char ch;
                  //string st;
                  for (int i = 0; i < n; i++)
                      while (strToParse[i] != '\t' && strToParse[i] != '\n' && strToParse[i] != '\r')
                          if (i == 0)
                              st = strToParse[i].ToString();
                          else
                              st = st + strToParse[i];
                          i++;
                      i++;
                      list.Add(st);
                      st=strToParse[i].ToString();
                      if (strToParse[i] == '\r' || strToParse[i] == '\n' || strToParse[i] == '\0')
                          break;
            /*    for(int i=7;i<216;i++)
                    if(i<=207)
                        Andata.Add(list[i]);
                    if(i>=210 && i<=215)
                        didata.Add(list[i]);
               for (int i = 0; i < list.Count; i++)
                    if (list[i].Equals("0") || list[i].Equals("1") || list[i].Equals("2") || list[i].Equals("3") || list[i].Equals("4") || list[i].Equals("5") || list[i].Equals("6") || list[i].Equals("7") || list[i].Equals("8") || list[i].Equals("9") || list[i].Equals("A") || list[i].Equals("B") || list[i].Equals("C") || list[i].Equals("D") || list[i].Equals("E") || list[i].Equals("F"))
                        String strr = "0" + list[i];
                        orglist.Add(strr);
                    else
                        String strr = (string)list[i];
                        orglist.Add(strr);
                byte[] orgbytes = new byte[orglist.Count];
                for (int j = 0; j < orgbytes.Length; j++)
                    //int i = Convert.ToInt32(orglist[j], 16);
                    orgbytes[j] =  Convert.ToByte(orglist[j].ToString().Substring(0,2) , 16);
                for (int x = 0; x < orgbytes.Length; x++)
                    FFrame.Add(orgbytes[x]);
                    DF.readBuffer.Add(orgbytes[x]);
                DF.BuildDF();
Message 23 of 36
(5,113 Views)
Accepted by danil33
This is not a .Net support forum!!!
A quick cursory look at the code shows exactly one connect(),and then you make a synchronous read to the socket and then start an asynchonous one and process the read from the synchronous read. What does your pfnWorkerCallBack_server() function do? Why do you mix synchronous and asynchonous processing? Have you studied asynchonous socket communication in .Net?
You either use synchronous receive and put the entire code inside the try code in a loop that terminates on disconnection and possibly other errors, or use asynchronous receive and put the entire processing inside pfnWorkerCallBack_server(). You could add the whole data parsing in pfnWorkerCallBack_server() too and then the first read would be synchronous and the rest asynchronous, but why duplicate code. Just use either synchronous or asynchonous but not both at the same time.
Message 24 of 36
(5,109 Views)
Sorry!!!.Thanks for suggesstion.
Message 25 of 36
(5,104 Views)
You need to give some more details.
What program are you stopping/starting to get it to work ? The C# or the LabVIEW program ?
How does your LabVIEW program looks like ?
Are you sure it is the C# program that is not working ?
What values do you expect to be updated ?
Is this all of the C# program you have shown ?
I'm missing some sort of while loop for the C# program to continue to read from the socket.
If this is the only C# code you are runing, then the program will only read the socket one single time.
There is also missing a close socket in the C# program.
This is just what I can see right now, but I'm sure there are a lot more missing.
Message 26 of 36
(5,100 Views)
Both the programs.
My labview program contains two listboxes for sending analog and digital data through TCP/IP.
whenever we changes any of the analog or digital data that value must be updated in C# program
please give some instructions,to achieve updation,SorrySmiley Wink I know this is Labview Forum
Message 27 of 36
(5,098 Views)
Please have a look at my labview program.
Message 28 of 36
(5,092 Views)
I can't the program [EDIT: Too late in my reply]
Sorry, but I'm not going to teach you to program C#. Or C for that matter.
But the rule is the same for LabVIEW as for a C# program. If you need at program to continuously doing something, you need a while loop.
I'm sure there are multiple forums for C# where there are people working with C# that can help you making a C# program that continuously read from the socket.
You know you can read one time from the socket, so you are close to the goal.
We can help you in your making of a LabVIEW program that sends data on a socket.
But for that to happen, we need to see your code.
Message 29 of 36
(5,090 Views)
Actually he mixed two different types of programming together. The first reading the socket in synchonrous manner one time with serverStream.Read() and the (commented out, I missed that in the first look) asynchonous one which gets started with soc.BeginReceive().
Whatever it is, there are still some lurking bugs in there. Unless he uses the undocumented/unsupported UTF8 nodes in LabVIEW, the stream will never be UTF8 encoded, and trying to read it with UTF8 encoding is likely to run into some problems. LabVIEW uses simple ANSI C for data strings.
Message 30 of 36
(5,070 Views)
