Interfacing Agilent signal analyzer via GPIB to LabVIEW
Dear Sir
I am trying to interface Agilent Dynamic signal Analyzer 35670A with LabVIEW signal express 2009 via GPIB (82357B, USB to GPIB) interface. But I have problems in interfacing.
I explain to you step by step process so that you can better understand the problem and guide me.
step 1. In mesaurement explorer, I click on devices interface and select GPIB-VXI inteface.
Step 2. Primary address was set to be 1. (Can you explain to me what this address means and what value should I put?)
I take the screen shots which are attached. Please guide me to rectify the problem. Thank You.
Kind Regards
Irfan
(2,947 Views)
Your question makes no sense since the instrument is not vxi based. SignslExpress also has its own board. LabVIEW users here don't use it so you should post questions about it to that board.
(2,927 Views)
Rereading your post, you mention the Keysight 82357. This GPIB controller is not related to vxi so your whole approach is wrong. There are special instructions from Keysight that you need to follow in order to use their controller with NI software including enabling tulip support. They are the ones you need to contact for help.
(2,918 Views)
