Internal Error 2727 netscape6pluginsdir
I had previously installed Labview 6.1 for some testing for documentation purposes. I had had Netscape 6 installed as well.
I've uninstalled Netscape 6. Now, I cannot uninstall the NI Labview Run-time Engin 6.1 from Control Panel. Also, when I attempt to run some select programs on my machine, I receive the following error:
NI Labview Run-Time Engine 6.1
Internal Error 2727: NETSCAPE6PLUGINSDIR
How can I correct this error? I receive 5 or 6 of these errors upon every startup. It's quite frustrating.
Message 1 of 8
(4,354 Views)
This is a problem with the Microsoft Installer Framework. One solution is to reinstall Windows 😞
Message 2 of 8
(4,354 Views)
If you knew which registry keys to update this would probably take a
minute to solve. Unfortunately, most registries are a rats nest. The
first thing I'd do is uninstall LV6.1 runtime, then reinstall it. You
might also try doing a repair to the LV6.1 installer -- if you want to
further trust the MS installer genies.
Greg McKaskle
Message 3 of 8
(4,354 Views)
The problem is that I can't uninstall the LV6.1 runtime. Each time I try, I receive an uninstall error and the uninstall will not proceed.
Message 4 of 8
(4,354 Views)
Look at this post
uninstalling LabVIEW Run-Time Engine 6.1 [link removed; thread no longer available]
Zvezdana S.
Message 5 of 8
(4,355 Views)
EXCELLENT!
Worked exactly as described. No more error messages!
Thanks so much.
PS - NI should put a link to this problem in it's support or FAQ sections. I can't be the only person who's ever had this issue.
Thanks again!
Message 6 of 8
(4,354 Views)
@Zvezdana S. wrote:
Look at this post
Zvezdana S.
Has anyone got an up-to-date link for this?
Message 7 of 8
(4,175 Views)
Hey Warren!
Here is an up-to-date link to that thread.  The actual solution went like this:
Here is my guess as to what happened:
1. You had Netscape installed on your machine.
2. You installed the LabVIEW Run-time Engine which installed the remote panel plugin into Netscape.
3. You uninstalled Netscape.
4. You are trying to uninstall the LabVIEW Run-time Engine.
If this is correct, then try installing Netscape again, uninstall the LabVIEW Run-time Engine, and finally uninstall Netscape again.
Hope this helps!
Andy F.
Message 8 of 8
(4,166 Views)
