Internal Error " typemgr.cpp Line number 1018 LabVIEW v7.0 German"
After Installing LabVIEW 7.0 German + NI-CAN/2 (series 2) by launching LabVIEW always I have recieved the following internal error:
LabVIEW error logfile and error message are attached.
My system is working under Windows XP Professional.
(3,385 Views)
Dear Narooz,
It seems that one driver is not correct installed.
Have you tried to install all NI products again?
If this fail again, let me know.
Hope this helps,
Best regards.
SebastianN
(3,385 Views)
Hi Sebastian,
Yesterday after uninstall and reinstall both LV7.0 German and PCI-CAN\2 v2.2, the system works again properly, I did not undertand why. (But this time after LV installation, I restarted the PC and then ran the LV by going through some example VIs, then restarted again and installed CANcard driver, I guess maybe activating LV once before installing Hardware drivers is very important.)
regards.
(3,385 Views)
