error type linker.cpp line 3386
I downloaded a Keithley2000 Mutimeter library form the NI site and when try to run some of the VIs get the error type linker.cpp @ line 3386. And the Labview will crash and go out.
(3,006 Views)
Dear Whobeid,
what version of LabVIEW, you use? Which driver are installed? What is your OS?
NI is only the portal to download the driver. The driver you get from Keithley.
Poste your VI, then I want to reproduce the error.
Best Regards.
SebastianN
(3,006 Views)
