Internal Warning 0xB78CFE1B: "window.cpp"
Are there any updates to this issue?  I am getting this error (see attached) if I call a function in my LabView Dll after making other calls to NI functions.  I am still trying to narrow down which NI functions (toolkit, DAQ, etc...).  If I call the LabView function repeatedly one right after another, I do not get this error.
Any input is appreciated.  Thank you.
Message 11 of 14
(921 Views)
I have found that this error does not occur if I disconnect the touchscreen monitor.  Unfortunately, this application requires a touchscreen monitor, so I am still in need of a solution.  Thank you.
Message 12 of 14
(915 Views)
We have a similar problem with LV 2013 and seems that disconnecting the touch screen solved this error
Message 13 of 14
(878 Views)
Yes, it worked for me. THanks.
Message 14 of 14
(305 Views)
