02-10-2006 12:06 PM
02-13-2006 06:45 PM
John123,
Before you can use a bitmap as your templete you will need to alter the bitmap so that LabVIEW recognizes it as a templete image. This can be done in Vision Assistant or Vision Builder for Automated Inspection, by loading the image into the interface and then running the color pattern match step on the image. You can then create a templete from the image and select the entire image.
If you want to do this from LabVIEW you will have to use the "IMAQ Learn Color Pattern" vi.
If I did not answer your question, please let me know.
Good Luck,
Lorne Hengst
Application Engineer
02-14-2006 05:56 PM
02-15-2006 06:13 PM
John,
I am not sure I can help solve this programming issue.
Are you sure you have properly imported your dll into your vb.net program?
Is there anymore information about this error? Line number? anything?
Lorne Hengst
