remote front panel connection
I want to view a labview front panel from a remote PC. But I only have one computer at the moment. So I am trying to simulate this  at local computer by setting the server address as localhost. But the connection is refused and it says: connection to a local labview application is not allowed.
Is that a part of labview feature or caused by improper setting in labview?
What should I do at this point?
Thanks for your reply.
(2,772 Views)
It is a LabVIEW feature. Remote front panels are meant to be used on two separate machines. If you want to set something similar from one computer only, you can try the web publishing tool that embeds the VI  in a htm page that can be viewed by using any web browser either on the same/ remote machine.
Ankita
(2,760 Views)
