Invalid requested id (web service labview 8.6)
Here you go!!!!
Message 11 of 20
(2,115 Views)
thanks a lot !! i'll take some time to try this out first
Message 12 of 20
(2,111 Views)
sorry to trouble again. when i opened the attached file seems got vi conflict and the client file is missing. can u give the full file one more time.
sorry for the trouble 😃
Message 13 of 20
(2,109 Views)
No Problem, attached project.
Should work.
Message 14 of 20
(2,105 Views)
thank you so much !! i already can get the XML data 😃
btw, can you tell me how then if i want to view through the client page ? what URL should i use ? i try with URL mapping /static and use URL http://localhost/ECG/static/Main.swf but cannot work =(
Message 15 of 20
(2,101 Views)
No there was no XML data, I tried initially didnt work. As if you need stream XML data following settings required.
For receving XML data use javascript function, publish into web page use following functions.
 XMLHttpRequest(),
ajaxGet = new ActiveXObject("Microsoft.XMLHTTP");
 ajaxGet.open("GET",http://localhost:8080/ECG/Array, true);
ajaxGet.setRequestHeader("Content-Type", "text/xml");
Message 16 of 20
(2,094 Views)
i already did according to your guide. i get the XML data but, still i can't view my client page. i got Acces Error when i try to open it.
i had attached my Flex client code and the project file i used. if possible can u try look at it =))
One more question, the flush output vi from my main vi seems having error. This happened when i try to run the main vi from the front panel. do you have any idea of this situation.
Message 17 of 20
(2,081 Views)
Give me some time to work on, as i dont have flash on my pc.
Message 18 of 20
(2,077 Views)
okay no problem take your time... i already thanks u a lot !!
Message 19 of 20
(2,075 Views)
hi! did you manage to solve it ? i'm waiting for your reply 😃
Message 20 of 20
(2,061 Views)
