Is Labview using closed file formats?
Are Labview's file formats like .vi or .ctl proprietary?
I'd like to programatically create (very) simple vis. Is there any documentation for the .vi format, however incomplete?
Are there any tools to export/import vis into/from open format files?
Is it illegal to reverse-engineer the .vi format?
Thanks!
(3,140 Views)
Accepted by f28
Yes, the formats are proprietary.
Maybe scripting will solve what you want to do?
About reverse engineering, you should carefully read your software license agreement. I am sure there are relevant passages. 😉
Message Edited by altenbach on 06-09-2009 01:57 PM
(3,139 Views)
Can you describe what you're actually wanting to do? What simple VIs do you need to programmatically create?
(3,110 Views)
