Is UDP fast or no?
Hi
 How I do one aplication in UDP mode capeble to aquire a 60Hz sign online?
 I do one hardware with dspic (Microchip)with 200ksamples AD converter and enc28j60 (stand-alone Ethernet Controller with SPI interface) at rate up 10Mbps and one LabView aplication in UDP mode with online aquisition byte at byte. At all I dont have one sample better that 333bps, what happen?
(2,435 Views)
Probably, the overhead of the message packages cause bandwith problems. Try to send the data per 10-500 bytes per message. You can also gain a bit by sending the data as singles, in stead of dubbles.
Wiebe.
(2,393 Views)
