Is anyone else seeing this with the report toolkit
I am using LV 8.6 and using the LV report functions inside a VI. This VI is my main VI for the TS user interface. What is happening is, I built my main vi into an executable and then I am building a deployment in TS with the executeable included. I get a tremendous amount of errors when I do this saying that the vi's that are part of the report generation in LV are not able to be loaded because they have no front panel or block diagram. So I did some investigating and sure enough the toolkit was changed to Object Oriented for LV 8.6. This explains why i can get it to build on a machine with LV8.5 installed instead of 8.6.
I was just wondering if anyone has had this problem with the toolkit and TS.
I also had a meeting with Brian Buress (field engineer for NI) and Jeff Phillips (LabVIEW product manager) they saw this activity (they were here and I showed it to them) and they could not explain it.
The problem has to lye in the fact that the report VI'S are now object oriented.
Is anyone else have trouble with this toolkit.
Joe.
"NOTHING IS EVER EASY"
(2,517 Views)
Hi Joe,
Yes, I also had a problem with the report toolkit.
See here for the problem and workaround
(2,495 Views)
