Is anyone experienced with Newport Electronics iServer-Microserver ethernet device?
I have been testing the iServer devices with alot of the same issues everyone else has been having. An additional item I noticed when stress testing the system is that if I used TCP queries in a reasonable fast loop the iServer would lock up and require a reset in 1-2 days. I seem to be having better luck using UDP and having the iServer broadcast. I haven't been able to get the TCP broadcast to work correctly yet and don't really need absolute timing anyway. Just thought I would toss that out in case anyone runs into reliability problems they can't explain.
Buddy Haun
CLA
Buddy Haun
Certified Trainer, Former Alliance Member, LabVIEW Champion
Message 11 of 15
(1,938 Views)
I sort of "intuited" that the device wouldn't be agreeable to being constantly queried... So, I set it to "Continuous" and let it deliver at its own pace. I test the incoming string for its first two characters (TA, TB, HA, HB, ...) and pass the resulting string to the appropriate chart, or numeric indicator, through a number conversion and an If/Then that repeats the previous non-zero value, until a new value comes along. My case logic is a tiny bit flawed, in that it will never pass along 0.00F, but I never anticipate my lab, or the insides of my devices, reaching that temp. Even so, it would pass 0.01F and -0.01F...
Cheers,
Stephen
Message 12 of 15
(1,932 Views)
Be careful just checking for a non zero number. The devices that I am using will randomly return -41.8F on the open temperature channels and -41.8% for the humidity. Most of the time the open "B" channels will sent back "Open" but not always.
Buddy Haun
Message 13 of 15
(1,929 Views)
When you say open channels, do you mean channels without a detector attached at the time?
Thanks for the heads-up!
Stephen
Message 14 of 15
(1,922 Views)
The IServers that I am using have a hydra attachment where you can attach two temperature/humidity sensors. If you don't attach the second sensor those channels may read "open" or a negative reading.
Buddy Haun
Message 15 of 15
(1,910 Views)
