Is is possible to insert a page break in an HTML report
I find the easiest way to generate text reports is to make an HTML template and then insert the data programmatically. The only problem is that, when printing, it looks terrible if a table is split between two pages. Is there any way around this?
(2,971 Views)
Try using the New Report Page.vi located under Function palette >> Report Generation >> Report Layout. This may be what you are looking for.
Feroz
(2,971 Views)
