Is it Labview8.0 support for GPIB-USB ?
Hi all,
I have a Programmable power supply which supports GPIB interface.
I would like to interface the instrument through LABVIEW8.0 software. For interface to Computer i would like to use GPIB to USB connector(Instead of GPIB to PCI).
Is it Labview8.0 supports for USB.
Thankq all
Mahesh.
Message 1 of 8
(3,963 Views)
Do you mean you want to be able to use something like this?
If so, than yes, LabVIEW 8 (and 7.1, 7.0, 6.1...) supports such devices. They appear to the OS as a standard GPIB port so you won't need to do any re-coding in your applications.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 2 of 8
(3,949 Views)
Hi Edwin Dickens,
Thanks for your reply.
I was exactly looking for the same thing what your mentioned.
It is very helpful for me.
Mahesh.
Message 3 of 8
(3,934 Views)
I got the Agilent USB/GPIB Interface converter (which seems to be the same thing as the one show in the link in message 2), and I intended to use it to replace the GPIB card/cable I was using before (I no long have access to it).
I am using LabView 7.1 to acquire data from an Agilent 34401A multimeter, using the HP34401 drivers. Since I removed the GPIB card/cable and installed the USB/GPIB Interface converter, my vi gives the following error: "Error -1073807343 occurred at VISA Open in HP34401A Initialize.vi" and then "Possible reason(s): VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system." Any thoughts on what I should check then? I used the 'Agilent Expert Connection' program and it detects the dmm...
Thanks.
Message 4 of 8
(3,865 Views)
never mind... I forgot to change the "Passport Tulip" option... now everything works fine.
Message 5 of 8
(3,855 Views)
hello,
firstly, sorry for my poor english...
and i have the same problem, a can't communicate with the same code.
and i don't know how tools use.
thanks
sorry again for my english...
Message 6 of 8
(3,838 Views)
hello,
thanks
Message 7 of 8
(3,839 Views)
I'm sorry but I don't know what you mean by "same problem". There's several postings here on this thread and they are all a little different. You should provide more details. Are you using a NI GPIB-USB or from some other company? What is the "same code" you are using or trying to use.
There's also a separate Serial/GPIB/VISA forum that you might want to post to if it's a problem with GPIB hardware or software.
Message 8 of 8
(3,833 Views)
