Is it possible to change the default PDF file name from 'LabVIEW Document.pdf'?
My application uses the 'Automatically print front panel every time VI completes execution' functionality to print front panels.  When I have my printer set to 'Adobe PDF', a dialog pops up and the default file name is 'LabVIEW Document.pdf'.  Is there a way to programatically set the name to something other than 'LabVIEW Document.pdf'?
I've already found a solution that manipulates the Windows registry, and I'm looking for another option.
Brent
(2,755 Views)
Do a search, as this question has come up before. The solution centered on not using the Adobe PDF printer driver but one that is intelligent.
(2,736 Views)
