how to generate an executable with lvclasses?
Probably there's a simple detail I've missed, but I can't understand what...
I developed my first project using LabVIEW classes, and It works fine into development system.
When I tried to build the EXE I found the VIs with the class functions in the executable folder. But I don't want to include these "source" files into the EXE directory.
If I build the EXE of the Board Testing shipped example I have the same problem (see attached).
How can I generate an EXE without these VIs in the output folder?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,002 Views)
In my case, my challange was to include those files so I will have to speculate.
You could put all of your classes in a dll included with the app. You will have to makes sure your paths in the exe are correct.
I'll watch for others (that actually know what they are talking about).
Ben
(3,996 Views)
The problem is that executables are built as an LLB and can't have two VIs with the same name inside them, but classes often have VIs with the same name (used for overriding). The solution NI came up was to place the class VIs outside the executable.
The good news is that NI is aware that people don't like it, so hopefully this should be solved soon.
___________________
Try to take over the world!
(3,984 Views)
The current solution, as has already been hinted at, is to put the class files into a separate LLB (you can rename this to be .DLL if you want to be *really* sneaky):
1. In the Destinations options create an LLB destination for each of your classes
2. In the Source File Settings options, set the destination of each class to be your newly created destination instead of "same as caller"
(see attached screenshots)
Shaun
Message Edited by shew82 on 05-19-2009 09:37 AM
(3,980 Views)
This seems not to work in LabVIEW 8.2.1...
I did a test with an evaluation of 8.6 and it works, ... but I need a solution in LabVIEW 8.2.1
Vix
Using LV from 7
(3,970 Views)
