Is it possible to create a variable size subVi (extensible)?
I was wondering if it is possible to create a subVi where its size (and imputs/outputs) can be extended. To be clear, something like the concatenate funcion, where you can change its size by making it bigger.
Message 1 of 8
(5,159 Views)
Right click subVI > uncheck "View as Icon"
Message 2 of 8
(5,140 Views)
That doesn't allow the drag to add more inputs, it just changes which inputs/outputs are visible. I think OP wants a subVI with an increasable size of inputs/outputs similar to Index Array or Concatenate Strings.
Cheers
Message 3 of 8
(5,132 Views)
Accepted by MrX_G
Good point, my suggestion really only offers a cosmetic change in the way your block diagram appears. OP, you could maybe look into XNodes to do what you are describing, although it will probably take some work. Last I heard they are a "use at your own risk" type of feature that is not officially documented or supported.
There is some info here to get you started:
http://forums.ni.com/t5/LabVIEW/what-is-an-xnode/td-p/1307516
Message 4 of 8
(5,113 Views)
All true, and while fun they are often way more trouble than they are worth.  Usually there is a pretty simple workaround that just uses a bit more code than you originally wanted.
And, as always, a relevant XKCD.
https://xkcd.com/1205/
Message 5 of 8
(5,071 Views)
Indeed there is, I will just stack single SubVi's, but I wanted it to be more space-efficient, just a matter of looks since others have to understand my code.
Message 6 of 8
(5,050 Views)
Seems it is the only way to achieve it, I will mark it as a good answer. Thank you.
Message 7 of 8
(5,043 Views)
Not really, no, the general solution to such scalability is arrays. Assuming you have a scalar or cluster input, place it in a wrapper and use an array of said cluster and loop through it.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(4,995 Views)
