Is it possible to create two task at a time using PXI 6259 DAQ card?
I am using LabView 7.1 and NI PXI 6259 DAQ card.
I need to write two channels at a time.Is it possible to write two channels at time instead of combining the virtual channels?.In my application i couldnt able to combine the signals since i need to write each channel of different no.of samples.
I have attached the file which i have created to write two channels at a time.When i am executing,it is giving an error as "The specified resource is reserved.The operation could not be completed as specified".
can u tell me any solution for this???
Regards
Meenatchi
(2,878 Views)
Hi Meenatchi,
Maybe, you should go thro' the link below.
ftp://ftp.ni.com/support/daq/pc/ni-daq/diagnostic/2.0/Readme.html
- Partha ( CLD until Oct 2027 🙂 )
(2,872 Views)
i couldnt able to see that page.can u please send any snapshots??
(2,870 Views)
Change the file extension from ".doc" to ".mht", of the attachment.
(2,867 Views)
