I am using LabView 7.1 and NI PXI 6259 DAQ card.
I need to write two channels at a time.Is it possible to write two channels at time instead of combining the virtual channels?.In my application i couldnt able to combine the signals since i need to write each channel of different no.of samples.
I have attached the file which i have created to write two channels at a time.When i am executing,it is giving an error as "The specified resource is reserved.The operation could not be completed as specified".
can u tell me any solution for this???
Regards
Meenatchi
