Is it possible to decimate or divide down the internal clock PXI 5105
Is it possible to decimate or divide down the internal clock of a PXI 5105 ?
Thank you
Heidar
(2,638 Views)
It should be possible to do a decimation by n where n is a U16.  (That's what the spec told me)
If you have the card the NI-Scope driver will choose the samplerate >= desired SR and you can check it with a property or vi after a commit.
If you need to know if you can solve your measuring task to buy that card contact your local NI and ask for a quote based on your requirements.
Greetings from Germany
Henrik
LV since v3.1
(2,632 Views)
Thank you for your reply Henrik.
I already have the card and managed to divide the clock (that was easy :D)
(2,607 Views)
Hi everybody,
I come back to you because I have an other problem.
I already have one digitizer PXI 5105 in a PXIe 1073 chassis and I am planning to buy an other PXI 5105.
I will use an external trigger and external clock for my set up but the problem is that there is only 1 input (PFI 1) on each card.
It means I will use the PFI 1 on card 1 for the external clock and PFI 1 on card 2 for external trig (I will use the 16 channels for my application).
We can share signals thanks to Export signal.vi so I tried for the trigger to export to PXI trigger line 0 (I put this vi after Digital trigger.vi ), it seems to work good (I do not have any errors).
But when I try to share the external clock I have an error like "Exporting a decimated sampling clock is not supported by this device."
So my question is : Is it possible to share the external clock via the chassis's backplane to synchronize both cards?
Thank you in advance for your answers
(2,565 Views)
yes that should be possible.
What other cards do you have in the chassis?
Is you chassis capable to sync to an external clock?
Henrik
LV since v3.1
(2,546 Views)
