Is it possible to dynamically create psp variables?
I'd like to be able to dynamically create psp variables on the fly.  Without getting into details; using straight shared variables defined in a library is too constraining for my application.  I've found that I can create PSP variables dynamically using DataSocket VIs in the System directory (psp://localhost/system/), though I can't seem to do it with the LV Shared Variable VIs.  I was just curious if there was any way to programmatically create psp variables without using DataSocket VIs.
(2,945 Views)
In the client yes,
Dynamically Creating Shared Variables
The SVE will automatically create the target variable with default properties when a client attempts to connect to a URL with the following format.
  • psp://computer/System/shared_variable, where shared_variable is the named tag for the data."
On the server you create them. I believe, if my memory is correct, if you have DSC option there is code to dynamically create them on server side.
(2,941 Views)
Maybe I'm missing something.  From what you say, the following should work:
But it results in an error 1018 - "unspecified error occurred".
(2,933 Views)
