01-19-2012 12:37 PM
I'd like to be able to dynamically create psp variables on the fly. Without getting into details; using straight shared variables defined in a library is too constraining for my application. I've found that I can create PSP variables dynamically using DataSocket VIs in the System directory (psp://localhost/system/), though I can't seem to do it with the LV Shared Variable VIs. I was just curious if there was any way to programmatically create psp variables without using DataSocket VIs.
01-19-2012 03:44 PM
In the client yes,
The SVE will automatically create the target variable with default properties when a client attempts to connect to a URL with the following format.
On the server you create them. I believe, if my memory is correct, if you have DSC option there is code to dynamically create them on server side.
01-20-2012 08:09 AM
Maybe I'm missing something. From what you say, the following should work:
But it results in an error 1018 - "unspecified error occurred".
