Is it possible to generate ev3p file by LabVIEW?
Recently I'm interested in the LEGO MindStorms EV3 series, and it has its own software MindStorms EV3 to program the project.
20160923002.pngAnd I'm wondering if I could use LabVIEW to create a customized block for this software?
Does someone has similar experience?
(3,107 Views)
Disclaimer:Haven't worked with it.
Here's something which might help you to start with : The NI LabVIEW Module for LEGO MINDSTORMS helps you control and program the LEGO MINDSTORMS NXT and EV3 with LabVIEW.
and this community link : https://forums.ni.com/t5/NI-Labs-Toolkits/NI-LabVIEW-for-LEGO-MINDSTORMS-LabVIEW-Module-for-LEGO/ta-...
uday
(3,095 Views)
