Is it possible to get 2D image using hilbert transform on Labview?
Dear labviewers
I wonder wheter it is possible to achieve demodulated image using hilbert transform on Labview.
Of course, it's possible to get 1-D profile using 1-D hilbert transform vi.
What I put focus on is possibility of 2-D hilbert transform on Labveiw.
As far as I know, there is no vi. related to 2-D hilbert trasform vi.
So, how can I make 2-D hilbert transform vi. by myself??
Use of multiple 1-D hilbert transform is simple and difficult to reconstruction perfect envelop signal, you know, due to only one directional application.
My version is 7.0 express.
Give me some tips plz^^.
(2,877 Views)
Hi gistguy,
I would start by searching around on the internet for free DLLs that perform the operation.  If someone has already made it, then LabVIEW can call it.  Hopefully you can find one. If you don't find one, this forum may help you:
http://forums.ni.com/ni/board/message?board.id=170&message.id=1303&requireLogin=False
It talks about how to use the 1D FFT and make it to a 2D FFT.  I am pretty sure the same process would work on the 2D Hilbert.  Anyone in the community want to back me up?
Brian K.
(2,849 Views)
