Is it possible to get a formula node structure to ouput a string?
I'm trying to get the inputs to be integers (coordinates) and the output to be a string that sends a command to the machine.
(2,636 Views)
A formula node will not output a string. However, you can easily create your machine command with the Format to String function. It is my favorite function in all of LabVIEW. Just drop it down and double-click it to configure all your inputs. You can format a variety of data types into a single string output.
Call on an Alliance Member if you want it done right the first time.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,636 Views)
