07-01-2003 07:00 AM
07-01-2003
08:07 AM
- last edited on
09-04-2026
12:24 PM
by
Content Cleaner
Thomas,
I tried to see this behavior and run into probably the same user "mistake". If you create an analog tag (w/ default settings) to e.g. dstp://localhost/random, the scaling of the tag would default to 0..100 and the update deadband of the engine is 1% - this means your DS Writer VI needs to change its value at least by 1.0 (but your random generator just changes value within 0..1). Therefore, the engine would never update the value because the deadband was not passed...
Attached is my test .scf file and your VI with the saved URL.
For further info you might check the DSC manuals or this link:
What is a Deadband? What Types of Deadbands Exist? Howare Deadbands Configured in OPC and the LabVIE...
Hope this helps
Roland
07-01-2003 12:30 PM
