Is it possible to have a cFP application that involves more than 8 modules?
I have an application that is using a cFP-2200 with an 8 slot backplane, but i need to read 9 modules and potentially more, is there a solution to this?  I know with the old field point there were expansion backplanes that you can use.
Any response is greatly appreciated.
Chris
(2,566 Views)
Hi Chris,
Yes, this is possible. Have you had a look at the cFP-1804 and the cFP-1808? Also, have a look at the following flash tutorial:
Ethernet Expansion I/O from Any PC or PAC
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,565 Views)
Thanks.
Would the1804/8 be accessible through the same IP address?  How do you link the 1804/8 to your original controller?
Chris
(2,553 Views)
I don't understand. The 1804/8 will have a unique IP address which can be assigned to it statically/dynamically from MAX, the same as you would do for any other NI PAC controller. You can, then, access the modules of the expansion chassis using the Fieldpoint API or shared variables, both using LabVIEW. Have a look at the link in my previous post and that should explain the process to you.
Message Edited by Adnan Z on 02-17-2009 04:37 PM
Adnan Zafar
(2,551 Views)
