Is it possible to limit the number of remote panel connections to a vi?
I have an application running on a RT PXI and I'm using remote panel to access it. My licence allows me to have multiple remote connections and it's ok as I sometimes need to open multiple remote panels at the same time.  However, I would like to limit the number of connections to 1 for a particular  VI.  Is it something that can be done?
Patrick Lessnick
(3,131 Views)
Patrick:  If you right click on your target PXI system in the project exporer, select Properties>Web Server>Browser Access you can select who you let have access to your VIs.   Likewise, in the Visible VIs section of Web Services you can limit which of your VIs you want people to be able to see.
If this isn't enough control, from your run time application on the PXI system you can write a startup VI (in parallel with your main application) to monitor the Remote Panel: Connections to Clients Property of the real time server.  Once this monitor application sees a connection you can take any number of actions to prevent more than one connection, deny access to specific IP ranges or what have you.
I am assuming you are using LabVIEW 2009 and MAX 4.6.1 but it may apply to earlier editions.
Hope this helps.
Bill
GCentral
(3,115 Views)
Accepted by plessnick
The way it can be done is to poll the clients that are conected to the VI through a remote front panel.  At that point you close the connection to anybody but the first person that connected to the front panel.  That way if someone is running the VI, nobody else can connect.  Once they are done, someone else can then connect to the remote front panel.  I created a community example that illistrates this behavior.  You can find it here:
http://decibel.ni.com/content/docs/DOC-9673
If you have any other questions, let me know.
Scott
Applications Engineer
(3,105 Views)
Scott:  Thanks for the far more elegant solution than I offered.  Did my response to Patrick help any?
Patrick:  Scott's solution cuts right to the chase - with my solution you would have had to learn how to do it on your own.
Bill
GCentral
(3,101 Views)
I would like to thank you both for your answers.
I already have a VI running in parallel to limit access to specific users (the customer doesn't want to limit the access based on the IP address) so those solutions will be easy to implement.  I would present both solutions to my customer and I'm sure he willl want to have both implemented.
Patrick Lessnick
(3,068 Views)
