I am trying to make a graph with multippel plots to use as a control, the plots should be drag and drop. Is this possible in LV 7.0 or do i have to use c++ or WB?
I second Doc-Doc comment. I am not sure what you are asking.
The attached is an example I found on the NI web-site some time ago. I cannot find the link again so here is a ZIP of what I found in a temp folder on my machine.
