Is it possible to make one element in a cluster invisible during execution?
Hi All,
I have a cluster of 5 elements. According to my search parameter the elements should go visible or invisible.
For example,
I have a Choose Function control with values - Pump, Valve, Delay
I have a cluster with the following values - volume, flow, set level, delay time, valve position
Now when I choose function to be Pump, I need only Volume Flow and Set level t get displayed. Whereas when delay is selected delay time only should display on the cluster, and the same with Valve.
Is this a possible scenario in Labview. Could anyone help?
Mich!
(4,255 Views)
Hi Mich,
yes, that's possible.
Use "Visible" properties of the cluster elements and set them as needed for each case…
(4,246 Views)
Hi Gerd,
I am not able to see Visible property in particular for element of the cluster. It is for the whole cluster. Could you please add in more information to make it clear for me.
Please take a look at the attached file where I see only "visible" property for the whole cluster and not for a single element in it, sorry if I ask you on a basic question...
thanks for your efforts!
(4,232 Views)
Accepted by MedicoMich
Hi Mich,
two solutions:
1) right-click the controls (in the cluster) to create property nodes connected with them.
2) read the "elements" property of the cluster to get references to the elements in the cluster. Use those references to make the cluster elements (in)visible.
Third solution:
3) Create a generic property node in the block diagram. Right-click it and select "connect to" (or similar, I'm using a German LabVIEW version). Then navigate the shown menu tree to select the control you like to manipulate…
(4,217 Views)
Perfetto!!!!
This is what I looked for...Thanks a lot, Gerd!!
(4,201 Views)
