Is it possible to minimize an already opened VI?
Hi, is it possible to create a VI that minimizes another VI?
I need a solution for this https://forums.ni.com/t5/NI-TestStand/Run-Teststand-Operator-Interface-minimized/m-p/3819853  and I'm trying to think outside of the box.
Any Idea would be highly appreciated.
Regards.
My Channel: https://www.youtube.com/@LV_Lab
Message 1 of 14
(3,961 Views)
Hi Garza,
Yes.
Spoiler
Get a reference of "another VI" and use a VI property node to change its frontpanel state…
Message 2 of 14
(3,952 Views)
Thanks for your answer!
But they have to be in the same LabVIEW project?
To create this reference from "VI_genericName" i have to modify "VI_genericName"?
EDIT: https://www.ni.com/en/support/documentation/supplemental/06/calling-a-labview-vi-by-reference.html is this what you meant?
Message 3 of 14
(3,950 Views)
Accepted by AldhairGarza
Hi Garza,
They have to run in the same runtime environment, so the VI server is able to find the VI.
You need to know the name of the VI to be able to get its reference: the VI name is one input to OpenVIReference…
Yes.
Read this sentence from the linked tutorial:
A required input for the Open VI Reference is “vi path”. “Vi path” accepts a string containing the name of the VI that you want to reference or a path to the VI that you want to reference.
Message 4 of 14
(3,946 Views)
Thanks! It works pretty well!
Message 5 of 14
(3,913 Views)
Is it possible to create a VI that minimizes a LabVIEW application?
Something with "Open Aplication Reference" and then some Method/Property Node?
Message 6 of 14
(3,931 Views)
Hi Aldhair,
you need to connect with the VIServer of your LabVIEW application using a network connection. After doing so you can also open a reference to a VI in the application.
Read the help for the OpenApplicationReference function…
Message 7 of 14
(3,897 Views)
I'm sorry but I can't fully understand how to do that.
I read the Help many times and I don't know how to tell the function to reference to my executable. Could you please be a bit more specific?
Thanks.
Regards.
Message 8 of 14
(3,892 Views)
Hi Aldhair,
you need to open a reference to the VIServer of your LabVIEW application.
To do so you use the OpenAppReference function and you need to supply the IP address and the port of that VIServer instance. The IP is given by the computer you run the app on. The port is 3363 by default, but can be changed in the application ini file, which is created while building the app.
Background: each app uses its own VIServer instance, even when running on the same computer. You can connect with other VIServer instances remotely using a network connection…
Message 9 of 14
(3,888 Views)
thanks for your answer.
"The IP is given by the computer you run the app on." Got it.
"The port is 3363 by default, but can be changed in the application ini file, which is created while building the app." I cannot find this port number, the ini file is the following:
[TestExec]
hideRootWindow=True
allowmultipleinstances = TRUE
dialogFont="Tahoma" 13
appFont="Tahoma" 13
systemFont="Tahoma" 13
ole.AuthnLevel=1
I also searched in the Build Specification but I cannot find the information. Am I doing something wrong?
Thanks.
Message 10 of 14
(3,881 Views)
