Is it possible to programmatically switch between a stack plot and an overlay plot in LabVIEW 7.1
Is it possible to programmatically switch between a stack plot and an overlay plot in LabVIEW 7.1 ? By reading some previous posts it seems older versions of LabVIEW didn't provide any means for this.
If there is still no way of doing this has anybody out there figured out a slick way hiding/showing a dynamic number of stacked/overlayed plots?
(2,928 Views)
The feature of enabling and disabling the stack/overlay plot property programmatically is not yet available.
Until it gets implemented, I would advise you to use a method like the one presented in the example called �Stacking Plots Dynamically in LabVIEW�.
Philip C.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,928 Views)
