Is it possible to prorammatically move a control out of a case structre
Hello, I have to programmatically move a control out of a case structure, when i try it, it makes the case structre bigger and keeps the control inside. Would be great if someone could help me fixing this, if it is possible.
Here is a pic of my test vi blockdiagramm.
Message 1 of 16
(4,074 Views)
You need to change the owner of the item from the While structure to the Block diagram.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 16
(4,047 Views)
Thank you very much for the fast answer, sadly the Owner property is read-only, is there another way to change the owner?
Message 3 of 16
(4,037 Views)
You can delete the terminal and create a new one on the Top diagram, and in this case it'll be easy. If you have connected wires it'll be a mess though. Why are you doing this? 🙂
/Y
Qestit Systems
Message 4 of 16
(4,025 Views)
Accepted by topic author Seau1
So: You cannot change owner from the same VI that runs, you must edit an inactive VI.
The function you missed is Invoke node - Move. That both moves and changes owner.
Qestit Systems
Message 5 of 16
(4,019 Views)
/Y
You also loose connectivity to the connector pane. This is really a lot of work to fix.
Message 6 of 16
(4,013 Views)
wiebe@CARYA wrote:
/Y
Then i found the Move-command. That solves a lot. 🙂
Qestit Systems
Message 7 of 16
(4,010 Views)
@Yamaeda wrote:
wiebe@CARYA wrote:
/Y
Yes, that should be marked as solution, IMO.
I had the CP problem when moving all diagram code into a structure.
Message 8 of 16
(4,004 Views)
Just curious - and you don't need to answer this - but what is the purpose of doing this programmatically?  It's just for my personal knowledge, in case I run into a similar situation.
Thanks!
Bill
CLD
(Mid-Level minion.)
Message 9 of 16
(3,972 Views)
Thank you very much for the help, I will try your solution as fast a possible. I need this because I have to fix a VI Generator which saves the controls and indicators inside of diagramms.
Message 10 of 16
(3,904 Views)
