Is it possible to run Labview RT 7.0 with Labview 7.1?
Is it possible to install and run Labview RT 7.0 with Labview 7.1?
(2,920 Views)
I tried it and it didn't work.
Mike
(2,919 Views)
What is discouraging is that when you install Labview 7.1 it gives the option of installing support for Labview RT 7.0. If the two can't play nice together what is the point of the option?
(2,914 Views)
The LabVIEW RT 7.0 support that they offer to install isn't from LabVIEW. It's from the DAQ drivers. NI-DAQ ships with support for several version of LabVIEW and other products so you don't have to download several different drivers to get everything you need.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,897 Views)
