Is it possible to set my binary threshold's output into rgb color?
I processed an rgb image into a binary image with thresholding , now I want to make the result of the thresholding (1's) into a specific color.
1. is it possible to do it in vision assistant ?
2. is it possible to do it in labview ?
the blue is only for display purpose, that is 1 from thresholding, i want the detected area (blue colored area) become pixel with 255,0,0 value (red)
(2,029 Views)
If you just want to display your binary image with another color couple, you can simply edit the binary palette used to display the image:
Using Vision Assistant 2020:
1. Make sure your binarization step is selected:
2. Make sure the Binary palette is selected, then edit:
3. There you can select a different color for each value (0 and 1 in your case):
Using LabVIEW:
1. Create an IMAQ Image control:
2. Configure a user-defined palette programmatically using property nodes on this control:
There you can specify an array of up to 256 elements, giving the display color for each individual binary group (starting from 0 to 255).
(1,998 Views)
sorry for not mentioning
I want binary (2bit) --> RGB , by changing the 1's in binary to specific RGB color.
edit : i've thought of taking out every 1s pixel's coordinate, then changing its array element from 1 to rgb color, then convert it to RGB image, but i think the process is complicated. i just wonder if there's a simpler way. thanks
(1,974 Views)
Accepted by PULSE.Wannabe
OK, this was the second option: turning the binary image (U8) into a real RGB image (U32).
I don't think there is a direct way of doing it with Vision Assistant, but with LabVIEW you can do:
(1,953 Views)
Ah you can directly multiply it, i see , thanks so much
(1,891 Views)
