Is it possible to use USB Camera for labview without having to install NI Vision Modules?
Is it possible to use a USB Camera for LabVIEW without having to install the NI Vision Module?
If anyone has an example VI that I can look at, it is greatly appreciated.
Thank you
(465 Views)
(441 Views)
Having had the (sad) experience of trying to use a "USB Camera" that didn't quite adhere to the GenICam standards (but worked fine with the proprietary driver and software from the camera manufacturer), I strongly suggest downloading a "trial" version of IMAQdx and seeing how easy it is to acquire single images and multi-frame videos in LabVIEW.  [I agree with @Quiztus2].
(402 Views)
Accepted by DragonSnow
I tried the software in this link and it does work. You might need to do a little work ont his but I can confirm that it does work and the block diagram is laid out in a way that will allow you to see what this developer did to achieve USB camera connection without Vision or IMAQdx.
https://forums.ni.com/t5/LabVIEW/2-hours-finished-the-webcam-program/m-p/782481?requireLogin=False
Tim
GHSP
(351 Views)
Here is another possibility. I tried this one too and it does work:
https://forums.ni.com/t5/Example-Code/Video-for-Windows-avicap32-dll/ta-p/3491285?profile.language=e...
Tim
GHSP
(349 Views)
thank you. i will give it a try. finally going back to this.
(144 Views)
