Is it true that bundle by name can cause FPGA compiles to fail?
Well, the features of the project libraries are all luxuries I can go without--we don't actually have any name conflicts, and code module icon templates work--so basically the move to virtual folders is a solution. Now that I don't use project libraries my code compiles and executes exactly as expected and as simulated--bundle by name is no longer causing error 1000. My problem is solved. If you need my code to debug this problem I would be happy to provide it, but I need to get back to writing that sonar driver.
Gray Cortright Thomas
Franklin W. Olin College of Engineering
Engineering: Robotics
Class of 2012
Needham, MA
Message 11 of 12
(405 Views)
Thanks Gray,
I don't need your code as Brian already had it and linked to the CAR.
Best of Luck!
Joe Daily
may the G be with you ....
Message 12 of 12
(383 Views)
