Is labview version 5.0 support pci 6014
Actually we have taken from NI, NI DAQ PCI 6.9.3 AND PCI 6014 ,so my question is regarding that which version of labview support to this PCI 6014,and one more queryis that we have also taken VI logger 1.1 which require NI DAQ 7.0 Or above vs of NI DAQ driver software ,which is not with us ,in this case what u suggest that what i have to do.
(2,452 Views)
You have to decide between using VI Logger, using LV 5.0 or upgrade LV to LV7 to use both.
NI-DAQ 6.9.3 will support LV 5.0 and your card. NI-DAQ 7.x will not support LV 5.0 but it will support your card. You cannot have installed two versions of a driver at the same time in one machine.
If NI-DAQ 7.x is not on the CD with VI Logger you can download it from here.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,452 Views)
