Is possible to return an .exe to a VI ?
I have this issue, i need to recover the VI that I made, but the only file I have now is the .exe, lost my whole program in Labview, is this possible ??? ASP
(3,217 Views)
Accepted by i.galaviz
Was it a debuggable executable?  If so, you can see the block diagram.  If not, I've got some bad news for you.
(3,214 Views)
If so ? What could I do ?
Thanks !
(3,202 Views)
Thanks !
You have to program your VI again. You cannot revert an exe to a VI, unless you had debug mode on, see above...
(3,164 Views)
